<%@LANGUAGE="VBSCRIPT"%> ROCKCRAWLER.com - Bulletproof XJ Bumpers
THE ROCKBOX GETS
BULLETPROOF XJ BUMPERS
By Mike "TXJEEPER" Cohn
Once the ROCKBOX got side Boulder Bars for rocker protection, it was time to turn to the front and rear bumpers and assess what we wanted to do there. We discussed the different options and decided that we would look at our requirements and see who made a bumper that met them. Here's what we came up with.
Front: Rear:
  • Low-profile. No giant bull bar or light bars. Must be as tight to the body as possible
  • Must hold a winch
  • Must allow use of a towbar for flat-towing
  • Must be extremely durable and put up with all the abuse we can give it
  • Two D-rings
  • Once again, low-profile.
  • 2" receiver for a tow hitch or accessories
  • Air tank optional
  • Must be extremely durable and put up with our abuse
  • Two D-rings
We looked at just about every major bumper manufacturer and narrowed them down until we came to Bulletproof Manufacturing. Now in all fairness, we already have Bulletproof bumpers on our Wrangler, so we are very familiar with them and how they hold up over the years. When we were looking around at other companies' bumpers, we simply could not find a matching pair that both met our requirements and looked the way we wanted. Confident that Bulletproof would be able to get us exactly what we wanted and get it to us in time for Moab Easter Jeep Safari, we called up and placed our order.
Bulletproof diagramBulletproof bumpers are hand-made by expert metal workers and welders. As such, they do take time to build and ship. When you order a set of them, you should not expect all models to ship immediately - especially if you ask for custom modifications. While some models are kept in stock, others may take a few weeks to produce and ship out. Our Cherokee bumpers showed up just in the nick of time for us to get them on for our trip to Moab. Like everything else we did on the ROCKBOX project, we were bolting on parts right up to the minute we left. In fact, the diamond plate guards that go behind the rear wheels had their holes incorrectly drilled and the folks at Bulletproof made a new set, which were waiting for us at our motel in Moab when we arrived.
One of the things that sets Bulletproof apart from their competitors is how they build the bumpers. While some bumpers are made of formed steel, Bulletproofs are made of rectangular tubing, meaning there is no open back-side, making the bumpers much stronger. In addition, clevis/tow-bar mounts are made for 3/4" bar stock steel and go through the bumper and are welded at both ends, ensuring a strong mounting point. Once complete, the bumpers are beautifully powder-coated black.
The front bumper we chose is a plain-Jane FF3L, which is made from 2” x 6” rectangle tubing with a 3/16” wall, as well as 3/8” angle, 3/8” plate and 1/4” plate. The top surface has diamond plate sections and the end caps are entirely welded, ground flush and completely sealed. It also has two D-rings. Several other models are offered with various grill guards and headlight loop guards, but we wanted ours to be basic and low-profile.
The rear bumper is the FF3LR-REC-SHK, which is made from 2” x 5” rectangle tubing with a 3/16” wall. Like the front, the end caps are entirely welded ground flush and completely sealed. This model includes a 2" receiver for towing, so it uses the same holes in the frame that you'd use if you had a hitch. The bumper is rated for 10,000 pounds and also has 2 D-rings and an air tank. We decided to mount our spare tire on a Wilderness rack on the roof, however, Bulletproof does offer a swing-out tire carrier, as well as Gerry can mounts if desired.
Bulletproof Bumper
Front bumper
Bulletproof Bumper
Rear bumper
Installation of the front bumper is fairly straight-forward. Bulletproof bumpers are made to extremely strict tolerances, and it is easy to think your bumpers were not made right if you don't line them up perfectly. Patience pays off when you realize just how perfect they do fit and you get everything put on right. Bulletproof provides all the hardware you need to mount your bumpers. Our bumpers were sent in a hurry so we could get going to Moab and we got shorted on a few bolt/washer/nut combos. It was not a big deal because they were standard Grade 8 and were available at Lowe's for just a couple dollars..
Bulletproof Bumper
Front bumper close-up
Bulletproof Bumper
Original front bumper removed
Pulling off the stock bumper is not a terribly difficult task, however, some of the bolts and screws in the frame and supports are a bit tricky to get to, so have various-sized tools handy. One thing you will need to figure out is a new place to house your vacuum ball. This baseball-sized plastic ball mounts inside the original bumper and has nowhere to live once you put the Bulletproof on. We tried tie-wrapping it to the frame for starters. During a long ride home on a hot summer night, our air conditioning stopped blowing out of the vents. A road-side inspection revealed that we had lost the ball somewhere on a trail or road. Plugging the hose got us home and we got a new ball the next day. We relocated the ball inside the engine compartment and everything works just fine now.
Bulletproof Bumper
You'll need to find a new home for the vacuum ball
Bulletproof Bumper
This piece gets tossed in the recycling bin
In addition to the ball, you will also need to do some trimming of the plastic inside the wheel wells. Because of the shape and size of the new bumper, the plastic does not look good and must be trimmed down and smoothed out so it's not sticking out or looking out of place. The trimming is easily done using a cutting wheel such as a RotoZip.
Bulletproof Bumper
This bracket needs to be moved in order to install the new bumper. It's very difficult to completely get loose. We decided to strong-arm it out of the way with a pry bar.
Bulletproof Bumper
The bumper attaches using existing holes in the frame. Once it's in place, we brought the bracket back to its original position.
Once you get the bumper in place and the plastic trimmed, it's time to put the winch in. Over the years we have been very happy with the Ramsey winches we've owned, which have included a Pro Plus 9000, a Platinum 9000, and a special-edition Bad Boy Platinum 9500. Having given us flawless performance, we decided to go with the latest winch Ramsey has to offer - the Pariot 9500.
Once again, our bumper was made with extremely tight tolerances. We lowered the winch down into the hole at a very slight angle and the feet got stuck in the bumper. A pry bar was needed to get the winch back out. We discovered the trick was to lower it perfectly straight and lined-up with the bolt holes in the bottom, because once it was in wedged in place, it wasn't moving. Though this sounds a bit like a pain, it actually is quite nice. We don't expect any thieves to be making off with our winch very easily!
Bulletproof Bumper
Our winch of choice for the ROCKBOX is the new Ramsey Patriot 9500, which provides 9,500 pounds of pull on the first layer of cable. It also includes a wireless remote.
Bulletproof Bumper
The mounting tray for the winch is very tight and fit the Ramsey perfectly - and we mean perfectly. You can see where we got the winch jammed the first time we put it in.
Cabling for the winch is easily run underneath the bumper and through the front of the Jeep and to the battery. We circled our extra power cable and tie-wrapped it snug up inside the bumper, out of harm's way. Our roller fairlead mounted perfectly to the holes on the front of the bumper and winch was ready to go.
Bulletproof Bumper
The Ramsey's roller fairlead mounts directly to the holes already in the bumper. The bumper will keep the winch safe and sound and provide a solid point of attachment.
Bulletproof Bumper
We bundled the excess winch power lines inside the bumper. They'll get a bit dirty under there but they are out of the way and should not get damaged.
Bulletproof Bumper
Our winch came with a wireless keyfob remote. We mounted the receiver to the Jeep's firewall, out of harm's way.
Bulletproof Bumper
The magnetic remote receiver antenna fit perfectly inside the bumper and is for the most part out of site of thieves.
Bulletproof Bumper
Completed installation
Bulletproof Bumper
Moving on to the Rear --->>>
