JKS Quick Disconnects for
Jeeps
JKS
Alliance,
NE
- This new revolutionary QD design is length-adjustable by the
consumer for fitting different size lift kits and/or fine tuning
unlevel vehicles. Just two QD sizes will accomodate all three
TJ, XJ, ZJ vehicles from stock height to 7" of lift.
Each
floating poly bushing is a custom molded spherical ball with 11
degrees of misalignment angle and can rotate 360 degrees.
To
disconnect, simply slide the bottom bushing off the stainless
steel axle pin mounts and swing the entire "Quick Disconnect"
assembly up and out of the way.
The
combination of the tapered stainless steel axle pins and the unique
floating bushings now allow you to disconnect and reconnect on
unlevel surfaces. Can your current QD's do that? Also, one grease
zerk greases both fluted bushings at the same time. Each QD is
robotically mig welded and powder coated for unsurpassed strength
and quality. As always, they are a bolt-on item requiring no special
tools.
For further information, contact:
JKS Manufacturing
PO Box 98 - Alliance, NE 69301
Phone: (308) 762-6949
