Alliance, NE - JKS now offers Jeep owners a solution to their
vehicles’ most vulnerable brake system component. HD Extended Brake
Lines are direct replacements for the factory rubber brake hoses, and designed to exceed the demands of extreme Jeep applications. The heavy duty, 22” hoses virtually eliminate volumetric expansion to provide immediate brake pedal response and improved performance
regardless of fluid pressure or temperature.
The flexible Teflon® inner core is chemically inert and unaffected by
aging and atmospheric conditions. The inner core is protected by an
exceptionally strong multi-layer Kevlar, elastomer and stainless steel
braid. A translucent UV-protected vinyl jacket adds an additional layer
of defense and corrosion resistance, and one-piece adapters are
permanently crimped onto each end. All HD Extended Brake Lines are
pressure tested to an incredible 4,500 PSI, and far surpass all DOT and
MVSS-106 requirements.
For more information contact JKS at (308) 762-6949 or visit www.jksmfg.com
