Swap a 4.0L in for your 258 Bolting it all in the Jeep
Your transmission bellhousing will need a location to mount the crank position sensor. (The AX15 already has this mount). I have a friend that did this swap into a CJ-8 that had a 258. The engine bolted right to his motor mounts also. If you have a 4 cyl. Jeep you will have to cut off your old motor mounts and weld in new ones. You will need to find a location for your new computer and under-hood fuse box. I mounted the computer on the firewall where the newer Wranglers have theirs. The under hood fuse box was mounted to the side of the battery tray. The easiest way to do this is just to get a battery tray from a newer Jeep. I had the benefit of a fab shop to make my own mount. Wiring the Beast!
Most of the wires that run into the bulkhead connector are specific to your Jeep and can be left alone. I pulled out one wire at a time from my original harness and got rid of the ones that were specific to the old motor i.e. old computer. The only wires that you will need to splice are ignition, and any sensors for your gauges. Everything else should be specific to your Jeep and you do not have to mess with it. Basically you just plug the new harness into the motor; the plugs will only go on one way. Supply power to the new fuse block. It should have the battery cables attached to it. Make sure you have a good ground and sensor ground. I know this sounds pretty basic and it is really that simple.
