Spidertrax
Spidertrax Wheel Spacers for 2007 Wrangler JK
Longmont, CO - These 1-1/2”, 5 on 5", 6061T6 aluminum spacers are an easy way of spacing out front and rear 2007 Jeep Wrangler JK axles. Each kit comes with 2 wheel spacers, 10 standard wheel studs (pre-installed), 10 lug nuts, and Loctite. Each wheel spacer is anodized in dark blue, using a double anodizing process for twice the corrosion resistance. In addition, each wheel spacer is wheel and hub centric for a perfect fit. Proudly made in the USA. Retail - $99.95 Part # - WHS-010 Available November 30, 2006
These 1-3/8", 5 on 5" to 5 on 4-1/2", 6061T6 aluminum adapters make it possible to change your wheel bolt pattern. Simply install on a 2007 Jeep Wrangler JK and this adapter will convert your bolt pattern to the 1986-2006 Jeep Wrangler YJ & TJ bolt circle. Each kit comes with 2 wheel adapters, 10 standard wheel studs (pre-installed), 10 lug nuts, and Loctite. Each wheel adapter is anodized in dark blue, using a double anodizing process for twice the corrosion resistance. In addition, each wheel adapter is wheel and hub centric for a perfect fit. Proudly made in the USA. Retail - $99.95 Part # - WHS-011 Available November 30, 2006
These 1-3/8", 5 on 5" to 5 on 5-1/2", 6061T6 aluminum adapters make it possible to change your wheel bolt pattern. Simply install on a 2007 Jeep Wrangler JK and this adapter will convert your bolt pattern to the Jeep CJ bolt circle. Each kit comes with 2 wheel adapters, 10 standard wheel studs (pre-installed), 10 lug nuts, and Loctite. Each wheel adapter is anodized in dark blue, using a double anodizing process for twice the corrosion resistance. In addition, each wheel adapter is hub centric for a perfect fit. Proudly made in the USA. Retail - $99.95 Part # - WHS-012 Available November 30, 2006
©2006 Rockcrawler 4x4 and Off-Road Magazine. All Rights Reserved
