Edge Performance
Edge Trail Jammer Module for Jeep Liberty CRD
ARB Tire Kit
Ogden, UT - The EZ is the ultimate performance upgrade for the driver that wants affordable on-the-fly adjustability, added towing power, quick and easy installation, and improved fuel.
The EZ offers a quick 10 minute installation that requires no expensive mechanic labor, no drilling, and no computer downloading. Simply plug the Edge EZ into 2 stock connections and you're ready to go.
The EZ provides real power and on-the-fly adjustability. You can switch between 3 power levels to add up to 25HP - all with the flick of an in-cab switch. The Edge EZ carefully monitors timing, turbo boost pressure, and fueling parameters to maximize power, torque, and driveability. The EZ safely provides power to help eliminate downshifting while towing.
The EZ is also tuned with a special fuel economy level* that improves the atomization of fuel, which in turn allows Edge to add power, while at the same time delivering between a 5-10% improvement in MPG when driving in level one. Add to that the EZ's price point and you have the ultimate value on the performance market today.
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge module. Power gains may vary based on vehicle and geographical location.
KEY FEATURES:
• Improves towing and driveability
• Gains up to 25HP and torque 40 ft. lbs.
• 3 on-the-fly Adjustable Power Levels
• EZ 10 Minute Install
For more information, visit www.edgeproducts.com
©2006 Rockcrawler 4x4 and Off-Road Magazine. All Rights Reserved
