Rear
ACOS
This is what you’ve been asking for! The Rear ACOS
gives the rear suspension of your TJ the same great adjustability
of the front ACOS.
The Rear ACOS gives a minimum of 1.25” of lift and
a recommended maximum lift of 2”. There is a new center
support, that requires welding for installation, included
with the Rear ACOS kit. The Rear ACOS can be added to all
most any existing suspension setup.
Manufacture
list price for Rear “ACOS” is $240.00 per pair.
Application:
1997 to Current, Jeep Wrangler
“SBS”
Steering Brace System
The SBS
is a reinforcement system of plates will solve the frame
cracking problem around the steering gear mount on the XJ
frame section (Unibody). It also take into consideration
the mounting of a winch bumper and it also moves the tow
hooks from being mounted vertically to being mounted horizontal
configuration. No more bending tow hooks over from being
hit on rocks.
The
SBS is a double plate, one inner and one outer, with connecting
sleeve that go thru the frame. The SBS is a total weld on
system. It must be welded on to the XJ. It also comes with
new steering gear grade 8 bolts w/ washers. The inner plate
is 1/8” thick and the outer plate is 3/16” thick.
The oval holes in the plate are for rosette welding the
plates to the frame.
The
SBS can also be installed on the passenger side of the XJ
for reinforced winch bumper mounting and to gain the advantage
of the horizontal tow hook configuration.
Manufacture
list price for a single side is $86.00 (OGS960) and $152.00
(OGS962) for the double kit which does both sides.
The
SBS is REAL Steering Gear reinforcement for your XJ
Check
out www.orgsmfg.com
for more info and pictures!
