Monroe,
MI Take your H2 to the next level. Rancho
is pleased to introduce the industry’s first suspension
system for the 2003 Hummer H2. Available in red or black
finish, and for vehicles equipped with coil or air spring
rear suspension. Rancho is leading the way with easy installation,
precision cut components, the industry's highest quality
CNC machined cast nodular iron knuckle, and one piece MIG
welded reinforced Subframes. Experience the Rancho difference
and uncompromising performance both on-road and off. Rancho
is dedicated to offering you the finest engineered, highest
quality products.
Here
are just a few of our system’s impressive features:
- Provides
an aggressive look by increasing front and rear vehicle
height .
- One
piece MIG welded and reinforced subframe (Rancho exclusive).
- No
exhaust modifications necessary.
- The
industry’s highest quality CNC machined cast nodular
iron knuckle.
- Torsion
bar cross-member and front differential drop brackets.
- Heavy-duty
tubular subframe braces with urethane bushings.
- Allows
for use of O.E skid plates.
- Allows
for alignment to OE specs.
- Allows
for the use of larger tires .*
- New
extended length progressive rate coil springs maintain factory
ride quality (RS6556 only)
- Aluminum
air spring spacers and longer rear height sensor links (RS6557
only)
- High-strength
low-alloy steel construction.
- Extended
front and rear sway bar end links.
- Factory
grade fasteners & hardware.
- Detailed
installation instructions.
Note:
* This kit was developed using a 37” tire on a 17X10”
wheel with 5.0” of backspacing. Factory wheels will
not fit with this suspension system.
The
NEW Rancho suspension system for the H2 will be produced
initially in very limited quantities.
